Home Forums Products Stompboxes Disabling incoming program change H9 Reply To: Disabling incoming program change H9
#145302
    You can't directly disable Program Change inputs to the H9 (sorry – no-one has asked for this).
    You could:
    1) Set [RCV CH] to OFF. This would disable MIDI CC as well.
    2) Set the [RCV.MAP] entries to OFF. This would be tedious if you had many PC's to consider.
    Neither of these approaches are ideal – normally if you send it a PC you expect it to respond.
