Home › Forums › Products › Stompboxes › Change Midi output mode on H9 via midi controller? › Reply To: Change Midi output mode on H9 via midi controller?
#145340
JCR
    nickrose wrote:
    You want to send it the following message:
    SYSEX_OPEN EVENTIDE H4000 id message_code  <lots-o-bytes> SYSEX_CLOSE
    where (0x means hex):
    EVENTIDE is 0x1C
    H4000 is 0x70
    SYSEX_OPEN is 0xF0
    SYSEX_CLOSE is 0xF7
    id is 0
    message_code is SYSEXC_USEROBJECT_SHORT = 0x3c
    <lots-o-bytes> is “25d <num>” this is a text string
    where <num> is 0 – XMT, 1 – THRU, etc.
    So, for example, to set output mode to THRU, you would send (all hex bytes)
    F0 1C 70 0 3C 32 35 64 20 31 F7
    It will reply with a similar message, but message_code will be SYSEXC_VALUE_DUMP (0x2E)
    That’s great. What would be the sysex format to enable/disable midi clock in?
    Do you have a sysex guide for the H9 with all of these commands and arguments described?
