Home Forums Products Stompboxes Change Midi output mode on H9 via midi controller? Reply To: Change Midi output mode on H9 via midi controller?
#145342
    JCR wrote:
    That's great. What would be the sysex format to enable/disable midi clock in?
    Same as above, but replace the 25d with 10a.  <num> should be 1 or 0.
    JCR wrote:
    Do you have a sysex guide for the H9 with all of these commands and arguments described?
    Not at present, both because it would be a lot of work, and also because many of these codes are rather technical and would require a lot of support. They are system-level stuff, with no error checking, so could give wierd and unusual results if abused.
