Home Forums Products Stompboxes Change Midi output mode on H9 via midi controller? Reply To: Change Midi output mode on H9 via midi controller?
#145345
    awjawjer wrote:
    So I ran the sysex message through my controller and it worked! To change it to thru: this message. F0 1C 70 0 3C 32 35 64 20 31 F7 But… I have no idea how to decipher the code to turn it to thru plus clock. Do you have that sysex string by chance? Or do you know how I can find it? I tried to run through a midi monitor with no real luck. Thanks so much! Adam
    In my description, the <num> parameter is the value for the parameter – this is the index of what you see when you adjust it in system mode. In the string above, it is the 31 at the end (this is ascii for '1'). Other values are:
    30 – XMT
    31 – THRU (as above)
    32 – THRU+C
    33 – MERGE
    other values should NOT be used.
