Home Forums Products Stompboxes H9 Ignores Preset Range When Using MIDI Footswitch Reply To: H9 Ignores Preset Range When Using MIDI Footswitch
#145518
    I'm not sure if I quite understand – preset range is more of a display function to limit the number of presets that are visible or can be stepped through.
    With MIDI, you control both the MIDImap, and the actual Program Change you send, so it would seem irrelevant.
