Home Forums Products Stompboxes Van Halen-First Album Reverb Reply To: Van Halen-First Album Reverb
#145535
floresp640
    I understand and Im sorry you are having this issue. From what it sounds like and from what I have tested, this is just the nature of the beast. You can't completely seperate the dry tone out of your reverb if you want just the tail. Can you try turning Pre-Delay all the way up to see if the dry signal you are hearing is delayed or not. If the dry signal you are hearing is not delayed then there could be an issue. Can you also try using a few other algorithms (i.e timefactor algs). I just wanna isolate the issue so we can figure out a solution or an answer.
