Home › Forums › Products › Stompboxes › Van Halen-First Album Reverb › Reply To: Van Halen-First Album Reverb
        January 23, 2017 at 7:47 pm
        #145562
So I tried a few work arounds that worked on my end here.
1.) With the 2 amp setup, turn the Early reflections to 0 and late reflections to 10. Turn the diffusion all the way up as well. This should give you less dry signal
2.) in terms of just using one amp, I would highly reccomend using an effects loop if your amp has it. Putting your reverb uin front will sometimes distort the signal. Putting the pedal through the loop will keep this signal clean giving you a closer reverb as to what you would find on the early Van Halen records.
Hope this helps!
