Home Forums Products Stompboxes H9 Causing Stuck Midi Notes Reply To: H9 Causing Stuck Midi Notes
#145645
gkellum
    themactech wrote:
    The only reason i have the USB connected was to access the H9 App on my Mac. I could use BT and access it on my iPad I guess and that will eliminate the USB connection
    You can use Bluetooth on the Mac as well.  The H9 Control user manual explains how to set that up at around pg 4:
    https://www.eventideaudio.com/support/downloads/h9-control-manual
