Home Forums Products Stompboxes H9 feedback in effects loop Reply To: H9 feedback in effects loop
#145715
    There is not a software option. If the hardware is overloaded, there is nothing the software can do.
    You can reduce the level with a 2-resistor pad (any competent technician can put this together for you). But, this will also reduce the output level correspondingly, which may or may not be an issue.
