Home › Forums › Products › Stompboxes › Latency doubles when H9 is used in Pre / Post routing mode. › Reply To: Latency doubles when H9 is used in Pre / Post routing mode.
March 6, 2017 at 1:49 pm
#145878
Unfortunately it's the hardware – any latency is in the analog conversion, and if the signal goes through the unit twice (as it does in pre/post) you will get double the latency.
Is there anything you can do with KILLDRY to help ?
