Home › Forums › Products › Plug-Ins › Each instance of Fission adds more latency in Ableton. › Reply To: Each instance of Fission adds more latency in Ableton.
April 3, 2017 at 3:40 pm
#146057
Hi-
Fission uses a complex process for separating transient and tonal audio, which takes a noticeable amount of time (latency). Many plug-ins do this, to some degree, and provide the amount of latency in samples to the DAW, so that the DAW can offset this latency (i.e. move other tracks back by the appropriate amount of latency) upon playback.
If you are recording something or have the Monitoring on in Live, then you will notice this latency, because Live can't shift tracks appropriately. When tracking MIDI, you should bypass Fission, or render tracks using it to audio.
