Reply To: Latency doubles when H9 is used in Pre / Post routing mode.
Home Forums Products Stompboxes Latency doubles when H9 is used in Pre / Post routing mode. Reply To: Latency doubles when H9 is used in Pre / Post routing mode.
#146191
To confirm – Pre/Post is a dsp feature added after the unit was designed – there is no special hardware to perform the routing.
As a result, both inputs have to go into the signal processor to be routed, meaning each one has to go through the A/D and D/A.
If the signal were to be ignored, it would not appear at the appropriate output.
