Home › Forums › Products › Stompboxes › Latency doubles when H9 is used in Pre / Post routing mode. › Reply To: Latency doubles when H9 is used in Pre / Post routing mode.
April 19, 2017 at 3:43 pm
#146201
workingtitle wrote:
Is the True Bypass Relay in the H9 only capable of switching both inputs and outputs at the same time?
It is – it bypasses the whole unit – that's what it is for.
Actually there are two bypass relays – one switches inputs and the other switches outputs – this is done so that one can precede the other and avoid clicks. This stuff is not simple.
Show More...Show Less...
