Home Forums Products Stompboxes Replacing the MIDI Connectors on all the Factor Pedals Reply To: Replacing the MIDI Connectors on all the Factor Pedals
#146228
    actioncamp wrote:
    well i don't believe the make a right angle micro usb cable so i'm not sure how much space you are actually saving. why not just get right angle midi cables? they wouldn't take up more space than a straight usb line
    There is something in what he says.
    If space is really tight, remove the casing from the DIN plugs and just use the pin inserts. Fill the cable area with epoxy if you want to make it more rugged.
