Home Forums Products Stompboxes One expression pedal for two units? (on A/B switch) Reply To: One expression pedal for two units? (on A/B switch)
#146234
13cwc13
    Quite by accident I discovered that one Expression pedal into the H9  also controls the downstream Time Factor…  both in the Fx loop of my Sansamp Ps1. That may be intended to work that way but… I believe I enabled the Kill Dry on both units. I really like it not only for the Fx blending but when I back the Expression pedal completely off all Fx evaporate leaving me with pure unadulterated guitar tone. Perfect for getting behind the singer without messing with the volume. The pedal halfway up provides a taste of both Fx and fattens up the sound, and when totally depressed the sound “Blooms” into total stage presence. As a plus you can preset both MIX controls to dial in the precise wetness of the ratio between the H9 and Time factor. It simply kicks ass!
