Home Forums Products Stompboxes H9 MIDI control Reply To: H9 MIDI control
#146370
    promero85 wrote:
    Hi, I would like to know if I can control 2 H9 via MIDI cable? I would like to load 2 effects (1 from each H9) at the same time. Thanks!
    You can if you set the first one to THRU.
    To load two effects with a single Program Change message, you will have to adjust the H9 MIDI maps to specify which effects you want to load. (See UM).
