Home › Forums › Products › Stompboxes › H9 Harpeggiator sync with external midi clock › Reply To: H9 Harpeggiator sync with external midi clock
May 25, 2017 at 12:05 am
#146512
Ok, adding that to the mix, I seem to establish steady sync (in Bitwig this time) by:
) indeed activating global tempo in the H9, after which I can leave ‘tempo on’ in each preset activated
) disabling H9 MIDI input clock
) sending the CC pulse, strange enough in 8th note pulses now. This results a in a correct BPM tempo (above H9 ‘tempo on’ button in H9 control)
This is all established through USB connection form PC to H9.
Strange workaround, I keep hoping for a more normal MIDI clock sync one day…
Will see if above method also works in Ableton..
Thanks for the tips!
