Home › Forums › Products › Stompboxes › H9 MIDI control › Reply To: H9 MIDI control
May 25, 2017 at 2:51 pm
#146518
promero85 wrote:
Just to be sure can I do this without using a MIDI controller? Just the two pedals?
If [PGM.XMT] is on, when you load a program using the H9 footswitch it will send a MIDI Program Change which can be used to load a program on another H9.
Use [XMT.MAP] to determine which program is loaded
Make sure [XMT CH] and [RCV CH] are set to the same numbers (or OMNI).
Set [OUTPUT] on the first unit to XMT.
