Home › Forums › Products › Plug-Ins › Fission AAX – please consider adding a ‘soft bypass’ or ‘On/Off’ button › Reply To: Fission AAX – please consider adding a ‘soft bypass’ or ‘On/Off’ button
June 5, 2017 at 9:43 pm
#146584
I have found that what is really happening is that when fission is bypassed the plugin delay is removed. This makes the delay compensation adjust every time the plugin is bypassed, causing the glitches. Every other plugin does not do this, and the delay (latency) is kept while bypassed. This makes automating the bypass impossible, instead I need to automate the mix control. Please address this in a future update.
