Home Forums Products Stompboxes Anyone Made An Electric Mistress Setting on the H9 Yet? Reply To: Anyone Made An Electric Mistress Setting on the H9 Yet?
#146956
    I’ve been meaning to follow up here with – if not a practical preset – at least an demonstrative application.
    DEPTH is set to 5, which you would think makes the sweep of the LFO barely audible.  Both the SPEED [1.0 Hz. – 3.0 Hz.] and MODFY DLY O/P [0 – 99]  are tied to the expression pedal travel.  So, the apparent ‘pitch’ of the manual delay offset, and the rate of the LFO sweep, will increase simultaneously.
    It’s a bit of a takeoff & landing effect, overlaid on top of the extraterrestrial chatter.
    For something a little more down-to-earth, dial back the INTENSITY to 50.  Chewy modulation – still with the ‘Leslie’-style ramping – but without the blatant vocal formatting.  Turning the INTENSITY all the way down to 0 will still provide some smooth & subtle modulation.  It becomes more layered, with dry input floating on top, and the sweeping effects pushed further down underneath it.
