Home › Forums › Products › Stompboxes › ‘Granular’ Capture & Playback – H9 / TimeFactor Looper › Reply To: ‘Granular’ Capture & Playback – H9 / TimeFactor Looper
October 6, 2017 at 12:48 am
#147360
This preset is about the same type of delay simulation, but a bit more tame & consonant. Establish the initial [REC] time, switch RESOLUTION to OCT+5TH, then double-tap to LATCH the delays.
Expression Pedal Heel: MIX 15 REC-SPEED 1/2x (PLAYSPEED 50) DECAY 85
Expression Pedal Toe: MIX 25 REC-SPEED 2x (PLAY-SPEED 200) DECAY 100
Pitch is shifted upward towards the Toe, and delay time is shortened to a single slapback. Wet signal is slightly increased. Slower expression pedal movement leads to a more delicate trail of pitched echoes.
