Home › Forums › Products › Stompboxes › 2-button aux switch › Reply To: 2-button aux switch
#147397
    The Factors will support TIP, RING and TIP+RING as separate switches. You could simulate a TIP+RING with two switches only if you were very precise – it is likely that one switch would make before the other. Better to use a 3 switch panel like Digitech FS300.
