Home Forums Products Stompboxes Where can I find a PDF of the Mixing Link Application Handbook? Reply To: Where can I find a PDF of the Mixing Link Application Handbook?
#147436
Berme
    Hi! Bumping this topic as I’d like a bit more information regarding the reamping thing.
    Before seeing the diagram above, I would have thought of sending my DAW’s recorded real or virtual instruments and vocals from my Scarlett output to the Mixing Link’s Line In thru a TRS balanced cable. Then, the now recently converted unbalanced signal would go thru the To Amp output to my pedals. And finally back into one of my Scarlett audio device’s instrument inputs.
    Is this method right or wrong for reamping? Should I follow the previous, not so intuitive, diagram above?
    Thank you!
