Home › Forums › Products › Stompboxes › Mixing link hiss, DI, and line-level › Reply To: Mixing link hiss, DI, and line-level
November 7, 2017 at 7:25 pm
#147605
jwaltz wrote:
Hi Charlie,
Not sure why the Mackie BlackJack Mic input works best with your setup when the XLR out is set for LINE level.
If the MXLNK pre-amp gain is set on the 'lower side' (ie. not peaking) it might explain this lower level at the MXLNK XLR out.
I'll take a look at the BlackJack user guide and chk their input specs.
thanks,
joe – eventide
That’s great, thanks! The MXLNK pre-amp gain is set at 12 o’clock, which I guess is unity gain. I shall try again, tweaking the settings with the amp disconnected to see if I can find a good mic level that way.
C
