Home › Forums › Products › Stompboxes › Adding a Swell/Volume pedal function › Reply To: Adding a Swell/Volume pedal function
November 29, 2017 at 11:50 am
#147777
For me a good enough solution would be a Volume algo, that you program as a preset which basically controls the volume via an expression pedal. I can recall that patch via midi if i need a volume pedal. Job done.
i would need to pre / post feature on the patch then i can have it at the end of the chain or at the start.
simples.
