Home Forums Products Stompboxes H9 Midi CC# Reply To: H9 Midi CC#
#147922
gkellum
    Savvy_David wrote:
    I'm just concerned that I may pick a CC# that is being used elsewhere and clash etc. I'm not tthat familier with midi but have some knowledge. At the the momemt my control app says 'no mappings' in the area you mentioned so does that mean I can select any number now?
    Well, that screen in H9 Control shows you all of the active assignments on the right side of the screen if you're using it on a tablet or a computer.  On a phone there's not enough space to show the assignments.  So, you can use that to see if CC 0 or CC 127 is already assigned, but I don't believe by default they are.
