Home Forums Products Stompboxes CC Set parameter controlling mix and other params Reply To: CC Set parameter controlling mix and other params
#148137
    During the time it takes to load a program the unit may also be processing MIDI messages, so it is possible that your CC is received and then the parameter is overwritten by the loaded program. If you send (essentially) simultaneous MIDI messages you can't really be sure in which order they will be handled. Sorry.
    It looks as though you should save the required settings as a preset, and then load it in the normal way.
