Home Forums Products Stompboxes H9 MIDI Clock issue Reply To: H9 MIDI Clock issue
#148210
    If you change a delay time with signal going through it  you get a pitch shift (this is how time domain pitch shifters work), which will typically give you a "whoop" sounds.
    Many of our algorithms crossfade between the new and old delay values to avoid this, but some of them ("Tape Delay" for example) allow it as part of the effect.
    You don't say what algorithm(s) you are using.
