Home Forums Products Stompboxes Timefactor: reassign right switch (on the pedal) when in Bank Mode Reply To: Timefactor: reassign right switch (on the pedal) when in Bank Mode
#148773
bohan
    babymicrobe wrote:
    Hi all, From what I understand it’s not possible to reassign the function of right switch on the pedal. At the moment I have an aux switch set to Bank Up – Tap Tempo – Bank Down. So basically the right switch on the pedal becomes redundant (except for going from Bank to Preset mode when keeping it pressed). It would be really useful to be able to reassign it to Repeat when in Bank mode.
    The onboard switches are not assignable. I would recommend you use it to increment banks, and assign your aux switch to Bank Down, Repeat and Tap Tempo.
