Home Forums Products Stompboxes Algorithm output level with expression pedal Reply To: Algorithm output level with expression pedal
#148805
bohan
    Mattedbass wrote:
    Im sure this has been talked about but i cant find anything on it.. Im trying to control the output level on the pitchfuzz plugin with an expression pedal as when the fuss is brought in the level drops (standard with bass) and want to boost the level a little with the fuzz.. But i cant set it like i do the other parameters.. Is there a work around?
    You can assign the expression pedal to control output volume on a preset by preset basis. Please see the attachment.
