Home › Forums › Products › Stompboxes › H9 Change Presets UP/DOWN by Footswitches › Reply To: H9 Change Presets UP/DOWN by Footswitches
March 26, 2018 at 8:32 pm
#148810
camn wrote:
IN RE REWIRING:
This would be trivial, I think. The switches are panel mounted.. so you could clip them easily. Then you would have to wire onto the inside of the jack… on the right side of the attached pic,,,but it is outside of the audio signal chain.. so pretty low-risk, IMO.
It would take an hour and 2cents worth of wire.. and would be a killer mod. You should do it!
Thanks for the info.. this might be the easiest solution for the moment.
