Home › Forums › Products › Stompboxes › H9 can’t tap tempo › Reply To: H9 can’t tap tempo
March 26, 2018 at 9:12 pm
#148814
wedelich wrote:
To me it sounds like MIDICLK IN is set to ON. If you’re not using MIDICLK, just go to the system menu and turn it to OFF.
I had a similar problem. I had been trying to get the H9 to sync to another unit via midi. It didn’t work, and I forgot to set the midi input clock back to off.
Thanks for a quick fix.
