Home Forums Products Stompboxes Switch Stereo to Mono Configuration via H9 Control? Reply To: Switch Stereo to Mono Configuration via H9 Control?
#148859
bohan
    jlane0710 wrote:
    Is there a way I am missing via the App to put the H9 in mono mode?
    With two output jacks connected, when you change your H9's routing mode to Pre/Post, your H9 will work in Mono configuration (with all presets in PRE mode and amp 2 turned off).
