Home Forums Products Stompboxes Spooky theremin sounds Reply To: Spooky theremin sounds
#148974
    For a theremin, you might consider a Whammy-like pitch preset through the Synthonizer.  Not sure how that would track … With access to an expression pedal, it might be good to run through all the pitch-based presets solo, and note how they track, crossfade, and/or glitch.
    The ‘pitch-shifting’ Delay algorithms (like Tape Echo) give unusual effects when adjusted, as do some of the Reverb algos with SIZE.  When I think ‘spooky’, it’s hard to avoid the BlackHole algorithm.  Plenty of multi-FX to fine-tune there.  Heavy modulation will bend the apparent pitch in freaky directions.
    Off the top of my head, here are a few preset links that may / may not help out here:
    Klang Mangle Organ
    https://www.eventideaudio.com/comment/21623#comment-21623
    Freak-Quency SSB
    https://www.eventideaudio.com/comment/25513#comment-25513
    Rubberband Glitch
    https://www.eventideaudio.com/comment/10897#comment-10897
    Poly Expressive 2
    https://www.eventideaudio.com/comment/31780#comment-31780
