Home Forums Products Plug-Ins BlackHole: some thoughts about mod.depth and tail length Reply To: BlackHole: some thoughts about mod.depth and tail length
#148986
Anatolyj_B
    Guys, sorry, for why you change infinite algo in latest versions ? Just now found that Infinity does not infinity anymore even if Depth and Rate modulation on zero. And the tail fade out very noticeable during this setting.
    I did not follow the versions, but did see list of changes, as i understand it is:
    3.0.4
    Fixes for several Pro Tools quick commands not working
    Fixes issue where delay compensation would change when bypassing plugin in Pro Tools
    Internal processing improvements
    > Fix issue where engaging “Freeze” would cause squealing feedback after long periods of time
    It seems it something related with this “fix” ?
