Home › Forums › Products › Plug-Ins › BlackHole: some thoughts about mod.depth and tail length › Reply To: BlackHole: some thoughts about mod.depth and tail length
Guys, sorry, for why you change infinite algo in latest versions ? Just now found that Infinity does not infinity anymore even if Depth and Rate modulation on zero. And the tail fade out very noticeable during this setting.
I did not follow the versions, but did see list of changes, as i understand it is:
3.0.4
Fixes for several Pro Tools quick commands not working
Fixes issue where delay compensation would change when bypassing plugin in Pro Tools
Internal processing improvements
> Fix issue where engaging “Freeze” would cause squealing feedback after long periods of time
It seems it something related with this "fix" ?
Hey-
We changed this because we found that in previous versions, Infinite feedback, with Depth and Rate at zero, would cause a squealing feedback after some time. This could happen as quickly as 5-10 seconds, if the filters were set a certain way, but regardless, it would always happen under around 30 seconds.
Show More...We decided to fix this, but doing so does mean that the tail will lose a bit of energy over a very long period of time. Were you able to achieve settings where this squeal did not occur?
