Home › Forums › Products › Plug-Ins › Blackhole and Ardour: no go. › Reply To: Blackhole and Ardour: no go.
#149271
jegelie
    Hi Tom,
    I’ve been discussing to and fro with Robin Gareus, one of the main developers on Ardour. It seems he can’t reproduce the error due to not having the same setup but judging from Ardour’s (coded) way of handling plugins it boils down on the same reason the AU does not validate and the VST does not initiate.
    Some other test from my side showed that the ‘auval’ tool validates fine (output: https://pastebin.com/0WF0BMHV), that the AU plugin is capable of running in Audacity and the VST freezes Audacity completely without logs or reasons when invoked, and that the AU plugin will not initiate in Garageband where it says it is not licensed and I need an iLok manager on my computer (which I do have, and the plugin is properly licensed).
    Also there is this entry over and over in my Console (/Library/Logs/PACEAntiPiracy/Eden/LicenseServices/LicenseD_000000.log):
    [ error] TPaceHttpClient::flush() caught a UtilException with this information:
    The HTTP server returned an “Bad Gateway” error (status code 502).
    There is no timecode on it, so I can’t retrieve when this is thrown.
