Home › Forums › Products › Stompboxes › H9 Midi vs Expression › Reply To: H9 Midi vs Expression
May 22, 2018 at 9:58 pm
#149298
AndrewWhitfield wrote:
mistercharlie wrote:
Yes, I use a MIDI expression pedal and it works just as well as a TRS one.
How do you set it up this way? If you please could point me in the right direction would be appreciated. I can see in the manual where it assigns cc messages to controls.. starting at 22 for the first control. But I cant see anything that explains how to map to the functions controlled by the expression pedals TRS connection. I'm new to this as you can tell 🙂 Thanks.
Press and hold the HOTKNOB and the right footswitch to go into the setting mode: MIDI -> RCV.CTL (CC message receive control) -> EXP.— -> set a CC message
If you use H9 Control (highly recommend it if you haven't), please see attachments.
