Reply To: Changing H9 presets with external switch
Home Forums Products Stompboxes Changing H9 presets with external switch Reply To: Changing H9 presets with external switch
#149455
gkellum
PaoloSMN wrote:
I have set up 2 of the 3 switches of a digitech fs3x to browse up and down the presets, but is there a way to make them automatically load without having to press the Active button? thanks in advance.
If you look under H9 Control under 'Pedal Settings' and the go to 'Aux Switch Mappings', you'll see that there are functions named 'Increment Preset' and 'Decrement Preset' but there are also functions named 'Increment and load preset' and 'Decrement and load preset'.  You'll want to use that second set of functions.  You can adjust this on the H9 itself of course as well.  Please check the user manual for instructions on how to do so.
