Home Forums Products Stompboxes H9 placement in FX Loop Reply To: H9 placement in FX Loop
#149499
bohan
rxb216 wrote:
So the current setup is: FX Send -> Whammy -> Pitchfactor -> Mobius -> Decimator in -> Decimator out -> Timeline -> BigSky -> FX Return
I’d like be able to use all the features of the H9 but I am confused about placement. It would have been ideal if the H9 had (2) FX loop connection options, such that I could place it both within the decimator loop (for pitch/modulation) and again outside of it (for delay/reverb).
I know that you have a pre/post option, but I think that's only applicable for users that want to place it in front of the amplifier as well as within the FX loop.
Hi, pre/post routing can be used anywhere in your signal chain. You can use pre/post routing so it can be used either in or after decimator loop depending on the pre/post setting of each preset you set on H9.
