Home Forums Products Stompboxes H9: any way to create a “manual” or “fixed” phaser patch? Reply To: H9: any way to create a “manual” or “fixed” phaser patch?
#149756
bansta
    He would like to have a posibility to set the SPEED = 0.
    I would like to have the same feature in the Flanger.
    bohan wrote:
    StSpider wrote:
    I want a patch where the phasing does not move, where the LFO is stuck in whatever place I set it with a potentiometer. Like in the electro harmonix bad stone, you have a “manual ” switch and you set the frequency with a dedicated pot.
    I want to do this without an expression pedal.
    So you want to use the buttons and the black knob on your H9 to control the parameter? You can try to assign the SPEED parameter to the XYZ buttons (anyone) on the H9. Then you should be able to do what you want by press the X (or Y, Z) button and turn the encoder to change the value.
