Home › Forums › Products › Plug-Ins › How to improve the Physion latency (2832 samples!) › Reply To: How to improve the Physion latency (2832 samples!)
Hi-
Where and how are you viewing the latency of the plugin? I can confirm here that the latency in samples changes depending on the sample rate. It should be 2832 samples for 44.1k and 48k, 5392 samples for 88.2k and 96k, and 8672 *10512 samples for 176.4k and 192k.
This does produce a noticeable delay of roughly 50ms, which of course is fine in a mixing scenario, but isn't acceptable for live use. Unfortunately, this is what is currently required for the structural split to work well. We hope to optimize this in the future.
-Tom
*EDIT: revised number of samples to be correct for 176.4k and 192k.
