Home Forums Products Plug-Ins How to improve the Physion latency (2832 samples!) Reply To: How to improve the Physion latency (2832 samples!)
#149875
tlongabaugh
    Sorry, 10512 samples is correct for 176.4k and 192k. I'll amend my original post to be correct.
    Keep in mind that the buffer size you are running will also factor into the roundtrip delay. 8192 is quite a large buffer size, and will cause a noticeable delay even without any latency-causing plugins, if you are trying to play anything "live".
