Home Forums Products Stompboxes Barn3 switch Reply To: Barn3 switch
#149966
bohan
    ginowong wrote:
    I am a little confused by your nomenclature.  Imagine you have an H9 with a Barn 3 switch attached, slide switch to the rear.  From left to right top to bottom, what are the footswitches named?  The apparent order of the switches does not seem to line up with logically with H9 control app. Finding a firm setup is hunt and peck and cycle power at the moment.
    You should set up their functions under Pedal Settings -> Aux Switch Mappings, and you can assign Tip/Ring/Tip+Ring accordingly.
    Please read this to find out what option you should use to assign each switch:
    https://static1.squarespace.com/static/539f0880e4b0e0318ea3192f/t/5940029fb8a79bde2d979ab5/1497367242457/OX9-Manual-2017.pdf
