Home › Forums › Products › Stompboxes › Tensor Fields [H9 – TimeFactor Presets] › Reply To: Tensor Fields [H9 – TimeFactor Presets]
For completeness, here would be one way to set up standard phrase looping in the Red Panda Tensor. Again, the total loop length here is locked in, between latches of the HOLD switch. Tap it once for a full-length of 5.8 seconds, and infinite, automatic playback in a forward direction.
Now, for the best way to emulate that variable record buffer, you really need external control over the Record, Play, Clear … maybe Stop. A number of individual Aux switches, or MIDI CC control, is going to make life easier. In this configuration, direct control over Play can ‘stutter’ the phrase, by restarting the record buffer from the start point. Here’s a description of the general idea:
https://www.eventideaudio.com/community/forum/stompboxes/exploring-h9-looper-midi-control
