Home › Forums › Products › Stompboxes › H9s and Temple Audio Pedalboards … › Reply To: H9s and Temple Audio Pedalboards …
September 20, 2018 at 2:18 pm
#150121
davebrubaker wrote:
This is a question for Eventide. I'm thinking about getting a Temple Audio pedalboard. They use a metal plate with doublestick adhesive that mounts to the bottom of each pedal. This would cover the sticker on the bottom of the pedal with the serial number. Does that create any issues with repairs or reselling if the adhesive damages the sticker? Thanks in advance for your help.
Well, you can also see a pedal's serial number by going into system mode under utils. So, this shouldn't cause any problems.
