Reply To: H9 to replace my Space and Timefactor
Home Forums Products Stompboxes H9 to replace my Space and Timefactor Reply To: H9 to replace my Space and Timefactor
#150244
4_cuerdas
bohan wrote:
4_cuerdas wrote:
Would I be able to use the H9 in the exact same way as my two stomp boxes?
Digitech fsx3 can work the exactly same way for the H9. But you can only use one algorithm on the H9. It cannot run a TimeFactor and a PitchFactor algorithms simultaneously.
I see, that is not a problem, I think that to be limited is a good thing. But do you know if it is possible to switch presets up and down with a MIDI pedal?
Cheers
