Home Forums Products Stompboxes H9 Pre/Post mode reverts to Normal mode upon power-cycling Reply To: H9 Pre/Post mode reverts to Normal mode upon power-cycling
#150308
silver_mica
    Isn’t that what I’ve already done?  A factory reset?   I did open an RMA ticket and will likely send in the pedal for repair today or early next week.
    Interestingly, I noticed what appears to be an extra menu item under the Route menu (when in System mode).  Here’s another unlisted Youtube video showing this.  It is my understanding that this isn’t normal.
    https://youtu.be/_YLCc3KU9OA?t=164
    nickrose wrote:
    If you have not already, try a complete Factory Reset (as described in UM). If that fails, you will probably want to send it in.
    There is one possible hardware problem that can cause nothing to be saved at powerdown, but this would include the current preset, so is noit the case.
    What you have is not a known problem, and I can’t think what would cause it.
