Home › Forums › Products › Stompboxes › Can the X, Y and Z buttons (in normal mode) be assigned to anything you want? › Reply To: Can the X, Y and Z buttons (in normal mode) be assigned to anything you want?
#150320
silver_mica
    That’s so rad!   Thanks!
    gkellum wrote:
    Yes, in H9 Control you can double click on any parameter and assign it to one of the X, Y, or Z switches.  On the H9 itself if you cycle to a particular parameter on an X, Y, or Z switch and save the preset it will save that parameter assigned to that switch.
