Home Forums Products Stompboxes Timefactor: When connected to USB no MidiClock follow Reply To: Timefactor: When connected to USB no MidiClock follow
#150323
    Sorry – not a bug but a limitation of the hardware.
    When it was originally designed, the USB was intended for updating the unit rather than control.
    As a result, you can use either USB OR DIN midi – if the USB is plugged in, the DIN MIDI is inactive.
